azj30fv wrote:Okay, so I troubleshooted my J30. Pretty sure my problem was the Radiator Fan relay.
It was missing, but in its place was a 30 amp fuse. When I re attach the fuse in the relays place the car starts, but does not turn off.
I bought a new relay for it, placed it in, but it will not start.
So, what would be the problem?
ANY HElP PLEASE!!!
30 amps is a BIG fuse. Is the relay also rated for 30 amps?
Please explain exactly what you mean by "the car starts, but does not turn off". The engine starts normally using the ignition key, keeps running, but cannot be turned OFF?
Turning the ignition switch should pull-in/activate/CLOSE various relays (wired in series and in parallel) and turning the ignition OFF should cause them to OPEN again.
It sound like in one case the relay isn't CLOSING (no start) and in the other the presence of the fuse will not permit other relays to OPEN (no OFF).
Pulling the fuse OPENS them, until you CLOSE them by starting the car again with the fuse in place.
I'd say your problem is upstream of the relay/fuse. The ignition switch maybe?
Modified by GerryO at 6:09 PM 11/6/2009
