JP72 »
https://forums.nicoclub.com/jp72-u195002.html
Tue Feb 28, 2012 6:04 pm
Disconnecting the battery wont hurt anything.. you can test the spark plugs by simply taking one out and have someone watch it while you turn the key. It sounds like it may just be a bad starter.. you could try hitting the starter with something heavy a couple times( jack it up so you can get a little swing) and if it starts, don't turn it off until you get a new starter and get home.
