please help, im stuck in alabama!
dwnshfter
Car: 91 240 rb20
ok, long story short, i paid way too much for an rb20 and install trying to help a friend out......7 months later it's still not done. it has turned over, but no fire yet. the m62 plug didnt match up so he had to cut the stock harness we pulled from the car and splice 4 wires in to make it plug in. this motor and harness has been in 2 other 240's and had no problems. i am running a fuel cell and a vortec T-rex pump and summit filter so i know i have fuel. he says that the ecu isnt getting power, but i have no idea. i need my car to run by the first to drive my fiance to the airport, but he's to busy to come finish his work so i gotta try and do it on my own. any advice or know where i can take it to get it running?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Check to make sure the 2 green relays near the ecu are in. Maybe thats what ur missing.
dwnshfter
Car: 91 240 rb20
is that on the m62 (i hope thats what its called, he calls it that) or the ecu plug?
Yellow4g63
If you look at the ecu and follow the loom back you will see 2 green plugs. Those need 2 green relays or else the car won't run. If you have those then u have bigger problems.
dwnshfter
Car: 91 240 rb20
****....the 2 green box things, those are there, i know for sure. what else can i do? do you think he's just putting me off for now till i move? he knows i am moving soon and i think he is trying to buy it from me for cheap.....
Yellow4g63
Well it's a problem with the harness then. If you don't want to pay someone to fix it then you might want to read these and try to redo it. http://www.racebread.com/old/D...a.doch ... /D...a.doc
dwnshfter
Car: 91 240 rb20
i just want the damn thing to run. i posted up in the regional forums looking for shops, if i can find one i'll go that route. thanks for the links, i will look at those in the morning. he said he thinks that he wired the m62 plug up backwards cause the diagrams he was looking at are for a rhd 240.......been 2 weeks and he hasnt been able to come and see if that was the problem..... thank you!
BoostFab
Car: S13cp, S13fb, S14z
is this going into a s14 240 ?
dwnshfter
Car: 91 240 rb20
last step, ground the ecu, that might be the problem....god i hope so.....
dwnshfter
Car: 91 240 rb20
90 sohc, sorry, shoulda said that
dwnshfter
Car: 91 240 rb20
prolly tupid question, but how does the ecu ground?
dwnshfter
Car: 91 240 rb20
well i towed it to shift_garage in pensacola today......ill post up and tell you what all they had to do. they seemed REALLY knowledgable and the owner acts more like he wants to help get it going than cash my check.....all in all i was impressed!
dwnshfter
Car: 91 240 rb20
well they are making my ic piping and ordered a fmic and are finishing up the fuel system for me. there is a local exhaust shop there going to use to finish up that too. i only wish i had the money for a greddy intake now
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
So did they fix the problem and if so what was it?
mehek
Welcome to Alabama! Take a good map and run you reasonable commute circle then hit all the For Sale By Owner sites. Community bnaks and credit unions have their foreclosures on-line. Let me know if you need help.------------------------------Mehek
Alabama Drug Treatment
dwnshfter
Car: 91 240 rb20
well its still at their shop and i havnt heard from them in a few days, i call but i only get the voicemail. i will post up an update later on today.
