sidewaysonmy180 »
https://forums.nicoclub.com/sidewaysonmy180-u87603.html
Sat Sep 06, 2008 1:20 am
ok so i was driving put it into 1st and all of a sudden my clutch pedal hits the floor. so i go ahead and change the slave after i changed it i notice that the fork had no pressure pushing against it back toward the slave ( its hitting the back of the transmission). so i take the transmission off change clutch pressure plate bearing etc . go and put the transmission back in and still no pressure. now the bearing slides up and down the shaft with eaz but still no presure. its as if the bearing comes no were near the pressure plate. some one help me im going crazy with out a car and i cant figure it out. im not the graetest mech but im not stupid. and the problem is not the slave cylinder. everything is workin up untill the fork. oh and its not the fork cause i tried a new one and same results.
