Mishka »
https://forums.nicoclub.com/mishka-u16371.html
Thu Mar 17, 2005 6:14 pm
Hello, everybody!
First things first it's a '95 240SX KA24DE.
Just a few days ago I noticed this knock from under valve cover at right above 2500 rpm. The sound seems to go away when I rev past 3500 rpm. The sound itself is like muffled knock. I hooked up an oil pressure gauge I had laying around and it showed good oil pressure, 45-50 psi at idle when cold, around 20 psi when hot. (I know it may sound a little high, but before that I replaced some of the oil with Lucas) With this oil pressure I guess I can assume that it can't be main or rod bearings. When I took valve cover off I found plenty of oil everywhere, everything is clean, no signs of damage of any kind.
The only thing I found that I didn't like is that the upper chain tensioner was sort of loose, I mean I can move it from side to side. Is it normal?
Another question is: How to check hydraulic lifters?
What you guys think?
