Sentientbydesign »
https://forums.nicoclub.com/sentientbydesign-u25395.html
Sun Jan 13, 2008 6:56 am
I would start with a clay bar. See if that helps at all. If not, then you could work your way up to a polish with mild abbrasives. You'll probably need a buffer for that. But try the clay bar first. It took off a lot of garbage off of my G, and my wife's Celica.
Also, if the clear is still partially salvageable, but you're worried about the thickness, you can have it re-cleared. The only time you can't is if the clear is completely gone and they have to start polishing the black.
