PLEASE HELP I NEED INFO ON A MOTOR CHANGE
240SX-IN-EVANSVILLE
Car: 91 240 SX AND A 77 DATSUN 280 Z
I HAVE A 91 240 SX AND I HAVE THE OPTION TO GET A 95 MOTOR. WILL IT JUST DROP RIGHT IN OR DO I HAVE TO CHANGE THE WIRE HARNESS AND COMPUTER CHANGE TO. PLEASE HELP ITS WELL NEEDEDTHANKS.
bcar240
Car: 1993 240SX HB
I believe it should just drop right in, but you might want to let someone else reply who knows for sure. Just to check, your not swapping out a working 91 motor for a 95 are you? They are basically the same, but the 91 actually has a tiny bit more power because of slightly hotter cams that year.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
There's no point in swapping a 95' KA24DE with a 90' KA24DE, unless you have alot of miles, and that's the reason why you're replacing it. There's no difference in horsepower or anything like that.
574-240sx
Car: Nissans, Toyotas, Subaru
Yes you need to swap to the S14 ecu and wiring harness.
