SICNESS »
https://forums.nicoclub.com/sicness-u8844.html
Sun Jul 20, 2003 10:27 am
OK I have a 1995 240 sx se ,no abs no lsd , made before feb 95 all I have done is a drop in k&n , hks cat back, unsprung clutch and the b&m shifter, the problem is one day my check engine light came on and the car started to sputer under constant speed and only after the car heats up. I start my car no problem drive reg and hard no prob but after it heats up say about 20-30 miles of driveing it starts to sputer and sometimes after sputering ther is no throttle until the rpms drop to 2400 then it is fine . if I push in the clutch and rev it the motor revs fine then i let out the clutch and the car is fine it accelerates like usual but when i let off the gas and press it again it sputers and the no throttle again. also the car stalls when i stop not to often but it does starts right back up no prob. the engine code i got was twelve 1 slow flash pause then 2 quick flashes this is a code for a mas air sensor i replaced it with a used 1 from the junk yard with in 10 minutes got the engine light agian and it threw the 12 again now i have thought that i might of bought a faulty mas air but before i went to return it I have replaced the fuel filter and o2 senser now i will be changeing my plugs but i wanted to see if you guys had any other ideas
