Please Help. I have a whole mess of problems!
dgracing29
Car: 1984 Monte Carlo, 1987 Rx-7, and 98 Nissan 240sx
Okay I have a S14 with a S13 Redtop SR in it. I have some light mods, intercooler, boost conroller, bov, comp clutch etc.
Well My car was having a hesitation problem where it would shudder and shake after it warmed up and I tried many different ways to try and fix it. Heres how it went down.
I changed the fuel filter, and the hesitation went away for a few days.
I rewired the MAF and it went away for like a week.
I re-did my Turbo intake pipe since it had a vaccum leak and the problem went away for a couple weeks.
I changed spark plugs to diff heat ranges and it still went away but the problem came right back again.
Tried a new battery, no different.
So then I went through a checklist of stuff to check and i did them.
Checked the Coils and the numbers came out right.
Checked the MAF and the numbers came out okay.
And then I checked the CAS and the numbers were fine.
So then I was reading on here that it could possibly be the IACV and that it needs to be cleaned.
So yesterday I cleaned it according to a post on here, and he said to use carb cleaner. I used about half a can.
After that it took me and hour to get the car fired back up again, and when i did it started to run like ****.
I let it idle hoping to burn off all of the cleaner but today I took it for a test drive. And it was running like hell and would barely stay on.
The major problem that occurred is while I was driving my gauges shut off, and then i noticed the a/c wasnt working, then noticed that really nothing electrical was working.No power windows, locks, brake lights, turn signals, and even radiator fans.
The engine runs (****ty), but no electrical accs are working.
The only thing that has changed before this problem was me checking the CAS ( possible to be bad timing when it put it back in). And me cleaning the IACV. I dont see how that could affect the electical accs but who knows.
I need your guys' input asap since its my daily and i need it in the morning.
Im not worried about the hesitation problem right now, just the electrical problem so i can at least drive it.
