s13sucksalot »
https://forums.nicoclub.com/s13sucksalot-u26167.html
Mon Jun 20, 2005 10:23 pm
I had the same problem with my car. Took me FOREVER to figure out. What you need to do (if you have access to an air compressor) is drain the system of water, pull the upper radiator hose off the block, then pull the hoses going to/from the heater core on the firewall. One hose goes straight into the block, and the other goes into some other part of the cooling system. Set the compressor to as low a setting as possible (luckily the one i had sucked and we could turn it down to like 5 psi) and slowly start shooting air into the block from the line going to the heater core. When i did this on mine, it gurgled sputtered then something broke loose and then water just started shooting out of the block. We think someone may have put some stop leak in the system when the radiator started to leak (before i got the car). The next step would be to do the same into the heater core. Some people would start SCREAMING at me at this point. As long as you are VERY careful and slowly apply pressure, you shouldn't have to worry about the core blowing up inside your car. What this is doing is checking for flow through your system. Once this is completed, do as nistech was saying and raise the front end of the car as high as possible and fill the system. I would also reccomend using water the first time (saves $$!). Start the car and let it warm up with the radiator cap off. Yes, there will be some spillage. After the thermostat pops open, look inside the radiator to see if the water is flowing. It should look like a little river. Another thing you should do, and i don't think it would be an issue b/c it's new, is check your radiator for flow. Pull the top and bottom hoses and put a water hose in the top at full blast. Check to see if the same amount of water is coming out the bottom as is going in the top. Hope this was helpful. Good luck!
