CandaceH326 »
https://forums.nicoclub.com/candaceh326-u264059.html
Tue Apr 26, 2016 10:48 pm
Hi guys, I have a 1987 v6 that my father gave me. Told me the ECU has gotten wet and that all I had to do was replace it. Things are never that easy though....the truck had been sitting up the 6 months prior to him giving me the truck. My husband and I replaced the ECU, air filter, main hoses, and made sure the gas tank is clean and the gas coming out is clean. Tried to crank the truck..... It turned over but wouldn't start. We can hear the fuel pump priming prior to cranking so we don't think there is an issue there. We have managed to get the truck to start a couple of times when he pours gas directly into the throttle body. It would start and run just for a few seconds before back firing through the carb and dying. We tried to pull it offand it started that way as well but still didn't run but just fora moment. When it did run there were giant clouds of white smoke, so much that fromadistance I thought the truck was on fire. We went in and changed the spark plugs and wires, the distributor cap , and the rotor. The dist. cap did have a couple of hairline cracks. We also replaced the throttle body position sensor at this time. Still nothing. My husband went back to double check the oil and it smelled like straight gas. Changed oil and oil filter this morning. Now every time we try to crank it still nothing but he can hear the gas damn near getting dumped into the oil!! He also said that when he replaced the distributor cap he noticed that the distributor was very loose so maybe that's part of the problem.
Can someone please advise me as to what the problem may be?? The truck ran perfectly fine prior to the ECU getting wet and ran fine the few times we did get it going. No horrible sounds or anything. .. Please help point us in the right direction.....
