nalz wrote:I would also check that the fuel pressure regulator has not ruptured its diaphragm and is gushing gasoline straight into the intake manifold (and engine). It's an easy check, just find the regulator at the rear of the intake manifold and pull of the rubber vacuum hose off of it, crank engine for a second or two and see if fuel squirts out (bad regulator), or if there's no discharge of any kind (diaphragm is intact). The regulators are normally very long-lived, but this one is nearly 30years old, and has endured the stress of a few backfires, so its worth a check.
My dad recommended something similar. He told us to take the fuel regulator vacuum hose off and seeing if a had a strong gas smell. That if it did then that was the problem. We tried that but it did not have a very strong gas odor...nothing that would seem out of the ordinary any way.
As of today.... When we turn the truck off after trying to crank it we can hear something still pumping or leaking fuel through to the intake. Ran the diagnostics on the computer and got a code 13 which is the cylinder head/water temperature sensor circuit and also got a code 43, which is the throttle sensor circuit, if I studied up correctly on the VG30i (which I am sure is what's in my truck). I did video the diagnostic test in case anyone thinks maybe my conclusions should be checked. I am not opposed to that since I have never done it before. We did just replace the TPS, is that the same as a throttle sensor circuit?? Is any of this making sense??
