virus77 »
https://forums.nicoclub.com/virus77-u14925.html
Fri Oct 02, 2009 12:04 am
how are you checking for oil pressure? Gauge, dummy light, cranking with no oil filter?
Is you fuel pump dead, run direct power to it and see if it comes on. If it does then just run the black/pink wire to the ground on a relay and a switched ignition to the other side to swtich it on. Have a nice battery + going to the relay with the output going to your fuel pump. Not only is this a mod but it will for sure run your fuel pump in case you managed to screw up the wiring earler(should be black/pink to black/pink). If you dont know how to wire a relay and you need more guidance read an articel on wiring relays. If you still dont get it, post here and I'll draw you a diagram LOL...
Seems like a lot of fuel pump problem lately.
