Infinibat »
https://forums.nicoclub.com/infinibat-u280117.html
Thu Mar 08, 2018 10:39 pm
I am getting the P0011 and P0021 error codes, changed the oil and filter,removed the solenoids and they seem to check out fine, put 12 volts across the coils and they function correctly. I put the solenoids back in. I then looked at the WIX oil filter I just replaced. I now see that the rubber anti drain-back valve is damaged, some of it might be missing. I am thinking that the rubber is now somewhere inside the engine in an oil passageway, blocking the oil from getting to the solenoids. Will i need to have the engine torn down? I don't know. I have not taken it to the dealer yet, but that will happen soon, I suppose. This could get expensive
