Fixer67 »
https://forums.nicoclub.com/fixer67-u6478.html
Fri Apr 11, 2003 6:45 pm
Some of the after market stuff you can get now days can mess with the on board computers. First unhook every thing that you hooked up and put every thing back the way it was. Now you will need to reset the computer. To do this you will need to unhook the battery and leave it off for up to 48 hours. The reason for leaving if off for so long is the computer needs to reset to factory specs. The down side of this is then time for one thing and when you do drive it, it may run real bad for the first little bit. The computer will need to relearn the car's settings. I have had to do this in the pass. Good Luck.
