blackbeauty240 »
https://forums.nicoclub.com/blackbeauty240-u509.html
Fri Apr 11, 2003 6:44 pm
where did you run the ground wire (inside the door jam) that might explain the door ajar light also which bolt did you use. sounds like you got to messing around with some wires in a parallel circuit that controls the radio, dome light and clock. your best bet is too get a wiring diagram and see if these componets are in the same circuit and see if you have a short, open, or loose connection. I know you didn't mess with hooking up the power but maybe when you where looking for a good wire to splice into you thouched a damaged wire to ground and now that wire is shorted. also if your in a parallel circuit you may have more than these three componets in the circuit that still work and therefore you have not completely grounded the circuit so you may not blow the fuse that controls these componets. I could go own and own and own but this is just my first assumption.
