Tastyratz »
https://forums.nicoclub.com/tastyratz-u8599.html
Tue Mar 16, 2004 7:06 pm
ok here goes,i have a 93 240sx se with a blown motor,my friend gram and i just got a 92 240sx to part out, and the plan was i keep the suspension and the motor, but he keeps i/h/e/ j30 lsd.
so i started the car when we checked it out, fine. started it after it was towed to the house, fine. (got towed because the radiator cracked so it doesnt keep coolant pressure and overheats on long distances)after trying to go down the street a little the car bucks HARD and stalls a few times, i wondered if id get it back to the house. the next day when i checked it out it was very very hard to start, would start sporatically, and die almost instantly. at first it was diagnosed as a possible fuel or ignition problem. i cleaned all the plugs (new iridiums) and changed out rotor since it was weak. i swapped the fuel pump with my other 240's walbro, and i swapped injectors and fuel rail today. i ran a compression test and got 155-160-162-165 which is within the acceptable range of 151-171 in the FSM. it starts now pretty consistantly, but still dies pretty consistantly. i cant get it to run for more than 20 seconds or so. it sputters and jumps and shakes, then dies. the last 2 starts worried me. the brake booster vacuum line is cracked, and when it died thoes times blueish white smoke came out the line. the last time a big puff of that same smoke came right out the intake filter. the exhaust always smokes similar to that. when the car runs it seems to be running rich, with the occasional backfire. ive had a few suggestions, that it might be headgasket, or valve seals. anyone else might have a few ideas on this?????
