please help, confused.
rbpwr240
Car: 240sx
Need help finding out what injectors to get for my rb20det I read to only use high impedance saturated injectors then I could use 89-91 rx7 and mk3 injectors straight drop in but there low impedence please can someone point me in the right direction. what kinda car do i get injectors from that'll work right in the stock rb20 without moding??
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
you have to purchase a certain resistor. It's called a droping resistor it changes the impeadance of the injector. HIGH OR LOW. There's a guy that had one for sale here on the forum. Do a search about injectors and i'm sure you'll find it. Any top feed injectors more than 270cc will work on the rb20det. Search the forum.
Carl H
there is really no general dropping resistor, you have to calculate what you need depending on the resistance of the injectors the you plan to use.ive got some hi-flowed 7mgte injectors from rc and they have an impedence of about 2.8ohms but the rb20 ones have a resistance of 13.5, so i need a 10 ohm reistor to compensate.you have to measure and check or go with a tried and tested combo like the rb26 injectors and the resistor pack.
rbpwr240
Car: 240sx
question: is there a direct drop in replacement from another vehicle that I can look for cheap? if not how do you add a resistor to each injector? I appreciate the help.
Sil240
Car: Nissan S13 "The One Cam Wonder"
hey does anyone else have a resistor pack with there stock RB20?? I belive mine is a early rb20 cause it has RB20 on the timing cover
240+civic=pimp
Car: s13/rb20det, 2002 WRX, 1994 Yamaha fzr600
There is no resister pack on an rb20det. THe injectors are high impedence. If you are putting on low impedence injectors then you need to buy a gtr resistor pack.I can get you one for $250I can also install it for you
