Wc240 »
https://forums.nicoclub.com/wc240-u133792.html
Wed Oct 21, 2009 4:48 pm
just becouse it says o2 sensor, doesnt mean REPLACE THE SENSOR. especially on obd 1. it means that the 02 is out of its perameters. this could either be that A: the harness between said sensor and ecu is mangled/compromised/jacked, orB: your motor is running bad enough that the level of oxygen that its reading(or not reading) is keeping it far out of the voltage specs it needs to be(wich is only about .1 to .9 volts, orC:you have an exhoust leak above(see, before) the sensor.none of wich would couse a backfire, but may couse a hesitation, running rich, lean, slightly to heavy drop in MPG, all depends on what exactly its doin
