Please Help. CLutch slave Cylinder Question.
JdrifterCA
Car: 1992 240sx LE
How do I determine if my clutch slave cylinder is working properly? I don't think mine is pushing as far as it should. Can someone please measure how far their clutch slave cylinder on their sr20 travel? I could use a ka24 clutch slave cylinder with on a s13 sr right? P.S. What kind of fluid do i use in the system?
Modified by JdrifterCA at 8:06 AM 6/15/2009
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
You can interchange them because the slave cylinders are the same for both engines/transmissions.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Make sure you bleed the system.
And yes they are interchangeable.
As for the fluid, the FSM tells you, I don't remember off the top of my head.
positron1
FSM states that the recommended fluid is Automatic Transmission Fluid or "DEXRON" type or equivalent.
