overboostwill »
https://forums.nicoclub.com/overboostwill-u75874.html
Tue Sep 11, 2007 4:46 pm
I have a 1991 ca18det 180sx , t3/t4 turbo , external waste gate blowoff valve , rich n lean guages , boosting at 15psi peak i currently dont have a boost controller to turn it down , new spark plugs kgn bcp7r . the first owner tuned it with a willem eprom board remove top sped limiter other things which am not sure , maf sensors , apexi air fuel converter . the car has stock injectors an fuel pump. when i drive it hard an go into to boost on first gear from 3500 its find up to redline , then when i hate second gear an run it up 2 above 5000rpm , i jerks as if the gear is finish no boost. cud the fuel pump an injectors be the as which a few friends suggested hear in nassau. or cud it be my computer setting on the eprom? please help .
