Lopin18 »
https://forums.nicoclub.com/lopin18-u58480.html
Tue Aug 12, 2008 3:00 am
HMmm suposedly u can use a walbro on our engine, but if the fuel regulator is shot, ur gonna flood the engine in fuel.
BTW, i had that same idle, engine shutting problem. Turned out to be my Crankshaft position sensor (the distribuitor has 4 cables comming out from below it, theres a sensor in there) if u can get a distribuitor and change urs ull see if its that..
The last distribuitor i had made my car have erratic idle, and dying, if i accelerated it it would misfire a lot and smoke a lot. Sooo try that, if not check fuel pressure maybe ull flooding it.
