please help cant get safc set up right
turbo-sil40
Car: 00' Land Rover Discovery, 1990 nissan silvia conversion coupe with CA turbo swap
the set up on the car is 450cc inj. T04E turbo I just put the inj. on and know i cant set the afc up can anyone help. the car wont enen start know. any suggestions im working on the car right now.
boost_boy
turbo-sil40 wrote:the set up on the car is 450cc inj. T04E turbo I just put the inj. on and know i cant set the afc up can anyone help. the car wont enen start know. any suggestions im working on the car right now.
Sell it . I'm just messing with you man! be patient as I'm sure one of the SAFC students will come in and point you in the right direction or you can use the Search button and I'm sure there's enough info on here to help you. If your car won't start, then you should put it back stock to make sure everything is working pre-SAFC. If it cranks in stock mode, then you can sort your issues with SAFC because you already know that your car and it's components are working.
Dee
