natedog437 »
https://forums.nicoclub.com/natedog437-u26359.html
Wed Jul 13, 2005 7:40 am
I have been having brake problems for the longest time. Everything has been replaced on my brake system like my master cylinder, pads, rotors, etc. There is still no pedal. There is no air in the lines and the car will stop, but it is only seconds after it has been on the floor. I thought it may be the brake booster, but my mechanic is saying the master cylinder is fine and it isn't my brake booster, it's the combination valve which consists of a metering valve, a differential switch and a proportioning valve. He is telling me that it is bad because I'm not getting any rear caliper braking. Could he be correct? The pedal feels completely mushy till it hits the floor and then has enough pressure to stop, the master cylinder that he put on has been tested and is good, and there is no air in the lines. Please help!
