Please help? 2006 Titan SE Crew Cab - Gear shifter won't go past Neutral...
eric_lord
Car: 2006 Nissan Titan SE Crew Cab
The shifter on my 2006 Nissan Titan SE Crew Cab was stuck in Neutral... I was able to get it into reverse and then into park eventually. However, I can no longer get the shifter into drive.
I don't believe it has anything to do with the shift-lock because that's supposed to keep it in park until you press the break.
All suggestions welcome.
audtatious
Well, worse case scenario is you have your Nissan dealer pick it up for repair since you should still be within the bumper to bumper warranty range.
The truck boys should post in here shortly.
