akers912 wrote:The other night I was driving my 1999 QX4 for about 30 minutes and when I got out I noticed steam coming from my engine. Turns out my engine was overheating. I popped the hood and noticed that water was dripping from somewhere right below my intake and was making a hissing noise. I was also smelling a lot of coolant. I couldn't figure out where it was coming from. My friend took off my radiator cap and once he did, all this dirty water came shooting out from the built up pressure. We let it cool off for about five minutes and filled my radiator back up with water. I drove another 30 minutes and my temp gauge stayed normal the whole way back. Has anyone ever had this problem or does anyone have a solution of what it could be? I'm thinking it's a loose hose or a clamp to something.
Hawairish wrote:First off, hopefully there's a lesson-learned about opening the radiator cap when it's hot. Your friend should be lucky to have not had boiling-hot coolant on his hands or face. It's stamped on the cap to never do that.
As for the fluid, there's a over-flow reservoir on the driver's side in front of the radiator. It's normal for there to be some coolant in the bottle, but if it's above the Max line, then there's a problem. You'll need to check other items, but it could be due for a new cap, pump, and/or thermostat. There are ways to test them.
Keep in mind that adding water is also only a temporary solution. The radiator needs distilled/demineralized water and coolant in a 50/50 mix to reduce corrosion and maximize cooling efficiency. If you had to put a lot of (tap) water in, you should plan on doing a flush to get it back to 50/50.
Also, one thing that can temporarily help an overheating engine is to run the heater, as coolant also passes through the heater core. Doing so might be enough to get you to the next stopping point.
I'm 95% sure I know what is going wrong and how to remedy it. The steam is from coolant obviously, I know, well it's steaming from pooling in or around the plenum and boiling. The air intake plenum is right on top the motor, k. This is common, common, for vg33e engines to vibrate the lower intake manifold gasket loose and cylinder number 2 will develope a coolant leak. These are metal gaskets, they don't tear, but the extra heart from that area causes this problem. NOW, the solution!!! This is a difficult job not the average DIY guy, you have to get down to the gasket between the cylinder head and the lower intake. A shop is likely to charge 300-400$ for this job, not to bad. But you can also do what I did, and it had worked for more than a year with 120° summers and extreme off road... people are going to send me to hell for this. I use bars leaks carbon fiber grade $50 bottle. I like the stuff, I'm an overland off roader and I like the added security it provides, I even bring a spare bottle for long trips. I've been using it for a year, it's temporary, I plan to fix that gasket along with other maintence all at once. I did a water pump job and added coolant to see if the leak was still a problem, it is still a problem after about 200 miles white smoke like a cloud out the tail pipe. Put in bars leaks carbon $50, back good as new, I'll red line it no problems. No leaks. ALSO!! There is a little 2" x1" house, "coolant bypass hose", cheap 5$ hose that commonly leaks in that same area. That is easy to replace, 20min or less. That little hose has been the death of some vg33e motors. 5$ hose could be a simple fix and it's less than a $50 bottle of bars leaks, and much cheaper than a 300-400$ shop charge to simply put more sealant on a damn gasket.
P.S. I think that the bars leak will remedy this small problem for the life of the vehicle, but next time you are have service done to the valve cover gasket, ask them to pretty please put some more sealant your sweet QX4 intake gasket.
