Chuby »
https://forums.nicoclub.com/chuby-u55212.html
Fri Apr 27, 2007 4:24 am
well I just did a JDM motor swap into my 90 standard g50 after the last motor dropped a rod bolt. Here are my problems.1st brake peddle has no movment and therefore the brakes will hardly work. You push the brake peddle and it moves maybe 3/4 of an inch and feels like you are pushing on solid ground.
Well while I was testing the brakes ability to hold the car still against the power of the motor in gear I appearently screwed up something else. Now the transmission pattern is all screwed up. Neutral is a forward drive gear, reverse sems to be neutral park seems to b neutral also. The car also will not rev past about 2500 3000 RPMs in any gear. What the hell have I done. Trans got drained while out of the car and I added a cooler and refilled it with M1 fluid.
Any insight to what I have doen would be nice.
