watch his hand at frame 30 sec, he flips the coin onto the other one to hide it. And watch how he holds the bowl...(you can guess where the coin is hiding..
Second trick 1:01... two coins are magnetic, so when he flip it they joined to be one coin, then he HOLDS the bowl in such a way...(still haven't guessed that he slips a coin in there?)
Third trick, 1:45, the ring is magnetic, he drops coin down on table... puts his hand over it, notice the ring is right over it... he hits the bottom of the glass causing a magnetic coin to stick to the bottom, when he raises his hand the coin near his hand rises, and the coin on the bottom falls. He palms the coin, watch his hand when he raises it, palm is concealed....
Frame 3:16 same thing, one side of the coin is magnetic, so when he hits it the coin flies up and attracts to the other coin, if you look at the upper right coin, you can sort of make out that it isn't real. As for the coin below, watch his hand, he's palming it. You can see him palming it at 3:15 if you quickly play and pause...
And the final trick...
http://www.filecabi.net/video/2084446350191.html
Modified by Rare_f8 at 9:53 PM 4/11/2010
