MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Tue Apr 27, 2004 3:00 pm
Can't help you with all of the questions.
Most T3's (OEM ones anyway) are internally wastegated. I don't know if you can switch to externally wastegated--why would you want to? It's a bit more performance oriented, but then you have more plumbing/welding to worry about, and I've read quite a few people having trouble with boost creep just as a result of incorrect angles of dumping the wastegate back into the downpipe.
Yes, you hear quite a bit about problems associated with non-recirc BOV's, (search, there was a post a while back about recirculating it) for understandable reasons-it's air that's unaccounted for (but then again, it's not accounted for the way I have mine setup), and most engines don't like open sources like that expelling air....most problems I've heard is with stalling, but some of the electronics out there work to eliminate problems associated with vented BOV's.
My BOV (actually, a bypass valve) is recirculated. If you recirculate it most people dump the air into the turbo inlet PAST the MAFS, angled toward the inlet if at all possible. You don't NEED to have your BOV on the cold side pipe, although it seems that's the popular thing to do especially if it is a true BOV; mine is on the hot side dumped back into the inlet past the MAFS.
How much boost you planning on running? T3's aren't bad and have beautiful throttle response for daily driving, but I get pretty sick of my T3 super 60 for its lack of flow in the upper rev-range (past 5k rpm). If at all possible, go with a T3/T04E or T3/T04B, either 50 trim or 54 trim, respectively.
Hope that helped a bit.
