please any one know what is code 138 2000 i30
paluli
Car: Infiniti I30t
,I took my car to an auto part and they told me, that code 138 and 139 my car is a 2000 i30t with 99k miles help please
Modified by paluli at 7:35 PM 5/31/2009
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
P0138 is "Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)"
This shows the location of all the oxygen sensors. Bank 1 sensor 2 is the bottom rightmost sensor shown.
paluli
Car: Infiniti I30t
thank you my friend. do you if that code also has some to do by my car not running right after 4k it seems like has no power.
crazyguy
paluli wrote:thank you my friend. do you if that code also has some to do by my car not running right after 4k it seems like has no power.
MAF sensor is bad.
paluli
Car: Infiniti I30t
now i have a code 139 also this is geting irritating. help me againg plz. and wherecan ibuy the parts.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)P0139 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)
You can buy O2 Sensor from NGK.com (@$90) or IoS (Infiniti of Scottsdale a.k.a. infinitipartsUSA.com >$125). Better call them instead of ordering on-line so you can give the VIN number, diagnostic code and other info about your problem. You have a better chance of getting the right O2 sensor that you need. Joe from IoS is very helpful to NICO member.
Rod
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
If you know how to splice wires, you can save money by buying universal O2 sensor @ $50 from Walker (oxygensensors.com) or Bosch (Boschoxygensensor.com). But you have to make sure whether you need the 3-wire or 4-wire sensor. Typical heated O2 sensor has 3 wires for Signal, Power and Ground. A 4-wire sensor has an additional wire for a dedicated Signal Ground (better in case of corrosion on the tailpipe).
A PB Blaster/WD-40 and an O2 Sensor Adapter (@ $10) will come in handy during sensor removal.
Rod
Amosnorider
I just replaced this sensor on my 2000 I30. try To find my post on oxygen sensors in the forum. Should help. IMO Buy the bosh OEM sensor.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
On my 95 I delayed changing out mine but had to deal withlots of "false" codes caused by my procrastination.
After I changed it out, the codes quit appearing.
paluli
Car: Infiniti I30t
thanks to every body and to this wed site, i fixed my car.
