stumpz »
https://forums.nicoclub.com/stumpz-u10771.html
Thu Jan 15, 2004 6:56 pm
well for my s13 redtop w/ stock mafs/370cc injectors the hot wire has to be set to 6 in and 6 out. w/ a z32 mafs and 370cc injectors it will be 2 in and 6 out. i am not real positive on if the settings will be the same, but if you have a ka24et instead of det it should be the same, because i used the stock 89 mafs for my sr. the det, i am not real sure about. i do know autometer a/f gauges do not work on our sr's (well they do but it's not the proper reading). i haven't gotten around to setting the dec air function yet. i have to do my swap in another 240 which i am working on at the moment. all i've done is the initial set up. i don't know if this will help you out or not, but i figure it may help someone else in the long run.
