centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Tue Nov 07, 2006 12:50 pm
I have a similar situation and would like some direction. Here's the details. Perhaps we have some common issues.
ISSUES:First off I have an s14 5speed and I bet you do to. Sometimes I get a bad start and the engine starts, bogs, and dies quickly. Other times I get a rough start and the engine will idle rough with dips between 400-600 rpms. Other times it starts rough, then smothes out at the normal 800 rpms. A cold start in the morning may create the first or third scenario. A warm start or restart will result in the second or third scenario. Something to note is that sometimes my temp gauge will look real shaky. I've even had the car run almost cold after running okay for a couple of hours. Okay, so the idle is a ***** and there may be a temp problem. Another issue which is scary and sucks is the cut out. I can't tell if it's fuel, air or spark, but something is missing. Taking off from a stop light I've had the car start to accelerate, then engine cuts on and off and shakes car violently. Will die if I step off of the gas, but sputters back up if I stay on it. Same happened in second and third. Wait, there's more... Other times it will cruise through town fine and I'll end up on the freeway. Car will run fine for a while, then almost out of nowhere, engine will start cutting (makes a loud buzz type noise). If I persist to drive the same, the cut outs increase until it kills my car. If I pull over, shut down, cool, restart, and go again. I can drive a while until the cut outs start to occur again.
HISTORY:There issome additional history I should mention. I have recently replaced my transmission. I couldn't get and s14 transmission so I put in an s13. My speed sensor on the output shaft does nothing that I know of. I get a working tach, but no speedometer. There was no sensor on the bellhousing at the flywheel so that sensor is just plain missing. The s13 transmission had an extra sensor on the side. Before these cut outs began, I was able to rev the engine up to 5,200 rpms before a cut out would occur in any gear. I also pulled, cleaned, and replaced seals and gaskets on the enginer (front and rear covers and oil pan). I put in new stiff mounts. My whole engine vibrates a ton! My AC was removed when I pulled the engine.
SUSPECTS:When all was working and rev limiter came on at 5,200 rpm, there may be a chance my fifth gear posistion sensor is stuck on, but I don't know. Do I do a continuity test?When idle problems exist I think I may need to test the IACV and IACV-AACV, the solenoid, and the wires. I have a manual, but the stuff seems rather inaccessable and I don't have a tool to do some of the tests mentioned in the FSM, any tips?When the fuel cuts out I read on this website that I may have issues with the fuel pump or my ground wires. I doubt it's either, but have checked my grounds and all are fine. Where do these fuel pressure measure devices come from? Where can I find out about my air/ fuel ratio?When I look in the FSM I found a page describing engine reving at no load being dangerous. So if the engine detects rpms in excess of 3,000 for a period of time (length unknown) it will automatically cut fuel until rpms drop back to 1500 or so then turn them back on. Does that clue help anyone to help me?
STAB IN THE DARK:So could my lack of speedometer create a no load situation and cause all of this? Do I have multiple issues? Where should I start checking stuff? Do I have to replace my speed sensor or can I test it or is it the one on the bellhousing that I'm not going to be able to get? Can any of these issues begin from getting water in a bad part of the engine while cleaning up old oil leak messes? My first fix, when it idled poor was to check my throttle position wires and to add a little air. That worked for a while until the cut outs began, then it went back to rough idle. What about removing my AC system? Could that cause issues with the IACV for the AC part? Does anybody live on the central coast with a consult and some free time this weekend?
