If I roll down a hill and drop it in 2nd gear ( haven't tried any other gear) it starts right up like a champ.....but never any other time. I just got the car back from having bottom end and top end built and was starting up fine when I turned the key and out of nowhere with no warning I inherit this issue which sounds more and more like a riddle every time I try explaining the symptoms so I can get the right diagnosis, I'm slightly mechanically inclined.... So my first thought was the starter is bad, so of course I had to wait on a new one for over a month because it was on backorder everywhere ........
So I installed the starter, direct replacement so I know it is wired correctly, and when I turned the key, NOTHING.... checked all the fuses, which still didn't fix issue.....
Got alternator tested after I got it jump started.... Mind you, it WILL NOT take a jump from another car via jumper cables, and they said the alternator is good ..... So now I am LOST.....
I had my battery (cheap valuecraft ) which was a sidemount setup relocated in the trunk just rigged up with electric tape linking the lead wires from battery to the original terminal points, and had starting issues in past dealing with bad grounds, so assuming that rigged trunk mount battery could potentially be part of the problem, I ditched it for a duralast gold battery (instead of my preferred optima redtop I was a hair away from buying) because it has a 5 year warranty compared to the 3 year optima warranty......
But anyways after installing the miata duralast gold new battery in, and extending the fuel pump wire up to the front through the firewall and to the positive terminal, but I DID ADD AN INLINE FUSE thinking I did the right thing? Fuel pump kicks in nice and strong (I always allow it to prime up before starting the car with the turn key method which I would kill to just be able to do right now lol.....
But what else could be the problem? It is such a pain and dangerous to be trying to roll the car fast enough to crank by dropping it in gear where I live .... And I'm trying to save a boat load of cash from having to drive to my mechanic who did the build because although he is the closest distance mechanic who can work on sr's to me, we are almost an hour and a half apart
