Playing Video through auxiliary input while car is stopped
anodyne13
Car: 06 Infiniti M45
I hooked my iphone up to the auxiliary inputs on my 06 M45 advanced tech package, but the video does not come through, altough the audio does. Im just trying to get this to work while the car is stopped. I'm probably missing something very obvious,
Any suggestions will be much appreciated.
FNAWSM
Car: Diamond Graphite '06 M45
is it in park with the parking break on?
anodyne13
Ahhh...Parking Break. Thanks. that will probably do it. :blush:
a.blanco0905
Car: 2006 Infiniti M45
91 300zx TT
07 Kaw ZX6R
I dont think u can output video through a regular RCA cable, because that jack is only for sound... you'd have to use an actual ipod cable & obviously we dont have that type of input in our cars (06/07 Ms.) But I could be wrong...
anodyne13
There is a multimedia cable that you plug into iphone and gives you RCA video and audio (3 RCA outputs. You can also plug iphone into a TV) the aux input on my 06 m45 has both the video and audio inputs.
FNAWSM
so did the parking break solve the problem?
EniGmA1987
Car: '06 Infiniti M35 Sport
You can also do the "Nav hack" to flip a switch and be able to get the video on the main screen even while driving the car.
a.blanco0905
91 300zx TT
07 Kaw ZX6R
anodyne13 wrote:There is a multimedia cable that you plug into iphone and gives you RCA video and audio (3 RCA outputs. You can also plug iphone into a TV) the aux input on my 06 m45 has both the video and audio inputs.
Oh cool, I'm guessing u have this cable!?!? And I'm also guessing you connect it through the bottom (where you'd connect the usb cable to sync with the computer.)
EniGmA1987 wrote:You can also do the "Nav hack" to flip a switch and be able to get the video on the main screen even while driving the car.
I need to get that done... but mainly to input addresses while driving instead of stopping and even having to set the parking brake.
anodyne13
yes. Problem solved. Now I can catch up on some Netflix on a lunch break or anytime I have some time to kill in my car.
anodyne13
Do a search on ebay for "iphone 4 video cable" and you'll get lots of results. You will also want a usb car lighter adapter sold separately.
The00Dustin
a.blanco0905 wrote:I need to get that done... but mainly to input addresses while driving instead of stopping and even having to set the parking brake.
To complicate things, you should know that you shouldn't need the parking brake for entering addresses. Also, that the hack is much simpler if you don't need the DVD part. You can use a SPST switch and only use it to open/close the VSS connection, the parking brake connection can be left intact (the parking brake connection is the one that you ground on the NAV side, the vehicle speed sensor is the one that disables several features when moving [or maybe above a certain {very low} speed, I say this because I swear I've been able to manipulate stuff at like .5 or 1 mph, but that could just be too slow for the VSS to show]).
a.blanco0905
91 300zx TT
07 Kaw ZX6R
The00Dustin wrote:To complicate things
Lmao...
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Hey blanco you dont have the nav hack donne on your car? I got it done here houston, I posted the name and address of the shop on the nav hack thread..... It's on 290 nw fwy. You should get it done next time you come to Houston.
a.blanco0905
91 300zx TT
07 Kaw ZX6R
Cool, thanks bro... how much do they charge for that?
redmaxima
Car: NISSAN MAXIMA 2009 3.5
recently i got a nissan maxima 2009, i just want to know how is the best way to hack the video aux with out press the brake
EniGmA1987
It depends if it has the same type of connections and Nav that our 06-07 cars have. There is a few differences in the procedure for the 08-09 models because they moved to a hard drive based navigation. So not sure at all what an 09 Maxima would need. Somewhere though you just need to splice into the VSS and parking brake signal wires that go into your nav area.
