cliffe5 »
https://forums.nicoclub.com/cliffe5-u271463.html
Mon Jul 02, 2018 7:54 am
Well after testing all morning here is what I've found.
If i line up the timing belt properly (lines on belt with marks on gears), i get interference after about a 300 degree turn (once the p side intake cam gear has traveled about 95% of a full turn).
Moving the p side intake cam gear counterclockwise (so now my belt timing mark is 1 tooth to the right of the sprockets' mark) and ensuring all other timing marks are still good, I still get interference about the same spot.
Now, if I continue to move the p side intake cam gear counterclockwise as described above, lining the belt up 2, 3, 4, and even 5 teeth to the right I can rotate the crank fully 720° without any issues.
With this knowledge, I believe if I can set my p side intake cam gear by the actual cam position (not the gear/sprocket) by way of removing the valve cover and lining up my timing there.
Can anyone tell me (show me) how a p side intake cam rests in tdc position?
