Platium Tip Plugs - The Best of the Best?
tonypatthou
In a battle of Platium Plugs for my 240, who would you guys most recommend. I will listen to your advise, and stories.
s13sr20chris
NGK! they are the stock plugs and they are the best. i have seen a million gabajillion nissans run bad on the wrong plugs. some people say they have good luck with denso, but dont ever use bosch platinum or el cheapos. even the high end european cars dont use bosch platinums. they use regular bosch super plugs. i personally use ngk regular(non plat) one heat range colder in my sr.
tonypatthou
I will always listen to the advice from a man who has "been there...done that". Many Thanks.
Tony
BadMojo
Car: 2007 Mazdaspeed 3
I can also swear by NGKs. I don't bother with the Platinum plugs either. IMO, NGK plugs and OE wires are the way to go.
NGK - No further discussion needed!
LSB_11
Car: cars, motorcycles, sports, flying,
i'v been runnin NGK's since i was four years old in my first rice burner, a kawasaki kx60, never have let me down. good ol copper works just fine.
