Plastic Radiator on S13?
Sleeper s13
Car: road racing
Yesterday I realized that my radiator was leaking. I kept on smelling a sweet smell like antifreeze, so i poped the hood and sure enough, right at the top where the foam shroud is it was spraying coolant. I think it was a thermostat that went south and took the radiator with it because when i added more fluid and tried to drive the temperature kept on spiking and i had to shut it down but there was plenty of fluid. I pulled into the local import mechanic shop and they took a look and told me that I had a crack in my plastic radiator! I was so suprized because i had always assumed it was aluminum. I geus im getting another plastic because an aluminum runs anywhere from 350 to 500. as where labor and all for plastic is under 300. I still wish i could upgrade such a piece of crap but thats wha happens when your a broke college student.:(
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
that radiator core is copper im pretty sure (at least on my car), maybe just the endtanks are plastic. Maybe the previous owner put a new radiator in an was to cheap to get a OEM replacement?
Replacing a radiator isnt as hard as people think it is. You could do it yourself and save a bunch of money.
Spoolin95GSX
Car: hmm...cars
I took the radiator out of my '95 Eclipse GSX in 5 minutes... I don't see how labor could be too much. If you bring it up here, I'll change it for ya right on the spot and only charge you a 6-pack :D . Also, I doubt that plastic has any cooling capacities at all, although the endtanks of almost all factory radiators are plastic. I'd say invest in a Fluidyne if you want to upgrade. Do it right the first time and never do it again.
