Moreoever, I live in a mid-urban level city with smooth pavement all-around, so I believe it must be worse for those Rogue Drivers living in harsher climates. I also recommend this mod for darker color Rogues since it is less noticeable unless you don't mind the look. I hardly notice it unless I stare at it.
It is really easy to do, just place a heavy coat in the area EXCEPT the area near the painters tape. After your done doing the area the last thing to do is a quick heavy coat near the painters tape to finish it off. This way it will be easier to remove the tape with no mess with it sticking to the tape.
As you can see the line is flawless and I did this when the weather was around 60 degrees on a windy day. It's best if it was 70 degrees.
Remember, the heavier the coat the thicker the protection.
ps- I actually did this before my accident and when trying to remove it, it seemed pretty durable. How durable? It was a PITA to rub off, boy my fingers were sore trying to peel it off. LOL
