ShadowKnight006 »
https://forums.nicoclub.com/shadowknight006-u7526.html
Fri Oct 03, 2003 9:33 pm
Ok I am getting ready to put the "new to me" Ka24e into my 240 and am preparing the car for the swap. The eninge and transmission are coming out together because i think it will be easier and I might be getting a less used transmission(still auto) for free. Well I was getting ready to disconnect the driveshaft and exhaust and ran into a few questions.....
A) What is the best way to disconnect the driveshaft from the transmission or remove it? A friend told me to unbolt it in the middle and the differential and it will just slid out?
B) I have noticed a lot of rust under my car, in odds and ends places. The most of it is covered in goo of some sort but the edges and supports and so on are rusted. What is the best way to remove undercarriage rust and protect it? I was thinking of stripping the "goo" off w/degreaser and removing the rust with maybe "rust reformer" and using one of those rubberized under coats?
The plan for the car is show&(mostly) go. This engine is just going to be in there long enough for me to add basic mods and rebuild the old engine fory the most n/a hp possible augmented by N2O use. I am not going to lower the car as the roads and pot holes around here would eat it alive. Here is what I hope to have as the final product(flame senses tingling)......
Short term--------------Engine: Ka24e(eventually built w/ N2O)Engine dressup: plug wires, new grounding kit, new hoses, etcColor: Red w/black highlightsRims: not sure yetIntake: InjenExhaust: Headers, high flow cat, and catback(2.25" or 2.5")Tires: Yokahoma(had 'em on my last 240 and loved 'em)Suspension: OEM springs(powder coated red) & KYB GR2sUnderdrive Pulley(s)Body kit: probably PDM side skirts & revalance w/ 89-90 front lip and either an erebuni spoiler or type x and shaved antennaInterior: Black w/ red high lights, reverse glow gauges, custom built in-car computer(I studied IT for 3 yrs), digital A/F, volt, temp gauges.
Long term Engine plans-----------------------------Ka24e(any mods from short term will be carried over or replaced)Rebuild & timing kitPDM stage II camsForged/coated pistons w/upgraded rods(?)New engine mounts not sure what type yet.N2O setup, no more than 100hp(MAX)
There it is any input is welcome, positive or negative. I will definately be doing a lot more research before I dive into building the next engine for my 240. Thanx for all the help I have already gotten.
-Levi
