planning to get 17X9 +20
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
I'm planning on purchasing a set of 17x9 +20 wheels. I have KYB AGX and Eibach Sportlines. would I run into fitment issues?
thanks
simmode1
Car: Red '95 S14
Nope. You're golden.
255/40/17's should do the trick if you want max grip.
nifares240
thanks for the input!
musashin
Car: 1993 S13 hatch
255 will be tough to fit, especially in the front of an s13. You'll need to run something like a 235 probably all around, unless you want to do some significant fender work.
What wheels are you planning on getting? I know the Falken Hanabi and FN01R-C come in that size.
240lookis
Car: 1990 240sx hatch
i have the hanabis in 17x9 +20 all around. however, i have a 25mm spacer in the rear.i am running 235/40 all around for now.i bet you could fit a 255 in front. maybe not with the spring/strut combo. you would need camber plates to dial in camber to -2.5* or so.
nifares240
FN01-RC235/40 I would wrap around with.
musashin
Car: 1993 S13 hatch
Where are you still finding those sizes? Private seller or a website?
nifares240
online
Modified by nifares240 at 11:52 AM 4/21/2009
