planning to bid on this item
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
http://cgi.ebay.com/ebaymotors...ZWDVW
one of the [few] flaws on mine is that the left part of the ashtray is broken. i can get it to stay closed, and so i don't mess with it. since i haven't *really* taken mine apart to see what is broken, will one of you kind fellow Q ers offer input as to if this one looks unbroken?
thanks.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
The seller says it is unbroken. It looks OK. The anlge of the picture make it difficult to tell.
Have you asked him?
mobiusinfinitis
Car: 1994 Infiniti Q45T
I had a similar problem with front ashtray. Took it out and found a little black plastic pin that fits through lefthand serrated, open close device. Replaced pin and ashtray has worked perfectly since. Maybe I was just lucky, but if you don't find anything physically broken i.e. plastic pieces, it could be an easy fix. Hope this helps you, and possibly others with similar problems. Even if pin is missing, it looks like it would be a fairly simple fabrication. About the size of the center of a round, tapered toothpick. Best regards.
Dennis(mobiusinfinitis)
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Jeff, yeah he said unbroken. I said is it show car quality? he said no--good but not perfect.not completely sure what that means.is that a scratch on the acrylic covering of the wood?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
thanks for the idea, you may have something there.
welcome to NICO, although your name looks familiar--were you here before?
mobiusinfinitis
GQ Jay, Yes, your memory is correct. I have posted several times and had password issues; hence the newbie sig. I am fairly new to Q's, and have picked up a lot of great info from all you folks. I am more than happy to pass along my share as well. I will try to be more active in my participation, as I have only begun to scratch the surface, and it's always good to have input when problems arise. Keep in touch and I'll try to be a more productive member. Wish I would have gotten in on the lowering springs for $200!!! Computer illiteracy and trying to run a dual boot system can create a bit of down time. If the fix involves a different ashtray, you should be able to fill or wetsand the finish, as it seems to be pretty thick. Best of luck.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I broke my ashtray one time when I was taking it out. you can just take a pin or a small screw and that will fix it.... As long as someone didnt try yanking at the thing thats what youll want to do....
