neverlift wrote:looks to be a nice build . . .
also why the 8.8:1? you can make a fairly reliable 350 on stock comp/pistons, I do understand they are better overall but comp can be dealt with via tune...
really the motor in either config is only as solid is the tuning/fueling
Thanks. I like pump gas and I don't have a lot of experience with real tuning. I'd like to keep it safe until I figure things out better. Once I have a better grasp of how my system works (either way I decide to go), I'll play around with ignition timing and boost levels.
WD, I'll answer some of your questions:
Why Holset? Because I'm in Michigan. We have so many turbo diesel pickup trucks around here, it's crazy. It's really easy to find turbos and rebuild kits and people who know how to work with them. Initial cost, parts, and labor are all very low cost.
To revist the MLS thing again, I just can't understand why people are having problems with these if they'd just do it right the first time. You have the procedure nailed down.
I all ready have the q45 throttle body - traded it to to derrick (doing the vh-swapped vert) for a pair of KA throttle bodies. I want to use it just because I have it and it allows me plenty of breathing room and some extra "wow" factor. Now to address the piping size selection: I'm just following the rule of thumb that your cold side diameter should match the throttle body and the hot side diameter should match the outlet of the compressor.
Selecting the DSM BOV was a lot like selecting the Holset turbo. I have DSM BOV's sitting around (I'm a DSM guy pretending to be a nissan guy). Unmolested 1G BOV's can be had for $25 and easily modified to reliably hold 30psi.
Thanks for the input
Modified by DeXteR at 11:27 AM 2/18/2008
