fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Thu Dec 18, 2003 7:33 pm
ehhhhhhhhhhhhhhhhhhhhhhhh
I wouldnt do it at 200k with no rebuild, and I wouldnt expect that it can get done (well) for under 1k.
First, like people said, DEFINETLY at least do a compresion test. I was in almost the same position as you- my 155k mile KA runs PERFECT- idles at 700 every time, doesnt burn a drop of oil, everything. I did a compression test over thanksgiving and guess what? I only have 130 psi in cyl #1. That pretty much shot my dreams of a turbo'ed stock KA right there. Do the test-- if you're satisfied with the numbers, then I guess its a possability, but Im tellin ya: turboing that car at 200 k is going to be nothing but a headache.
Equally, my experience has led me to beleive that a completed, well done KA turbo project for under $1000 is a fairy tale. Youre gonna be buying almost excusivly ebay or junkyard parts, and using a fuel setup thats pretty much less than ideal. I dont know about you, but if I was turboing a 200k engine, I would want to at least be able to trust the turbo parts, nevermind the motor..
I feel like with cheap(er) parts and an old engine like yours (and mine!), once the project is done it's just going to be a countdown till the first thing breaks. Dont think you can get this done for that amount of money, because either it should cost more on the outset, or it will cost you more down the road.
Save up and do it right!
