redheadedredtop »
https://forums.nicoclub.com/redheadedredtop-u25075.html
Mon Mar 14, 2005 4:23 am
Hey man, the 'full swap' is just a front clip....runs you about 3000 dollars to 5000 dollars, depending on whether you get the s13, s14, or s15 front clip. That is basically everything you need to do the swap. You should research on this site a little more and you will find everything else you need. Now depending on what you mean by 'runnin dang near perfect', that is a very broad question. That really depends on what kind of hp you are going for. As far as modding the motor before or after, I personally would wait until the motor is in the car and running perfect. Otherwise, you could mod it to death and put it in the car and not know what the problem is when it wont start up....but that is only my opinion. As far as a rebuild kit, you shouldnt need that until a while down the road, granted you run the sh*t out of that motor, but otherwise, if you can rebuild a motor, it should be < 1000. But if you have to take it somewhere, you could be looking at upwards of 3000-4000(these are just estimates, plz dont get mad if they are a little off). For purchasing the engine, that has been posted hundreds of times. I have only heard good things about HeavyThrottle and .....someone else...cant remeber now. As far as the coilovers opposed to struts/springs, I have only had struts/springs(koni yellows/ ibach ...something) and I loved them....they cost me about 500 total. Hope this helps a little bit.
