Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sun Oct 12, 2003 5:28 pm
Kind of important to know what you want from a rear sway bar! Exactly how many pounds of extra resistance per inch [wheel rate] do you want to add: 10,20,30,40, 50,60, 70, or 80 pounds per inch of diffferential deflection?What/how much do you want the front rear coupling ratio to change/ be?
Spend some time understanding the mathematics/physics of what you are trying to accomplish. Just throwing parts at something without a plan. Everything can be modeled and the exact changes calculated in advance within 5%.Stretch your mind as everything has been discussed in detail on NICO.............search my posts on Q handling and mods. The rear suspension on 240, 300zx, J30, Q45 is very similar.........even the spring rates are within 20% heaviest to lightest.
