nzmoman »
https://forums.nicoclub.com/nzmoman-u41093.html
Wed Jan 17, 2007 2:11 pm
you also may want to think about upgrading the intercooler also... the stock one will work, but if you are going to force more air you are going to lower the inlet temperature and run a little hotter. It will be smarter to have the front mount...and a back up turbo. And if you plan on keeping your car at 14 for a long time Id recommend getting some sort of basic tuning, (dyno if possible, but its not necessary)
Id be less concerned with the turbo messing up and more concerned with the motor. Turbos are easy to replace motors are too, but they tend to cost quite a bit more.
