stealthy_240 »
https://forums.nicoclub.com/stealthy-240-u137074.html
Fri Jul 10, 2009 1:39 pm
Is finding the TDC necessary for when i remove the rocker shafts? If it is how can i determine taht it is infact the compression stroke TDC. i will have the valve cover off since im replacing hte gasket. I see alot about the DOHC and its cam lobes pointing outwards. So im assuming TDC for me would mean the rocker arms both dipping down for Piston #1? THanks
