nismo180sxS-13 »
https://forums.nicoclub.com/nismo180sxs-13-u50477.html
Mon Nov 13, 2006 2:21 pm
ok so basically screw what these crappy instructions are saying, and just find the 12v+ constant. What I bought was a 6-12v circuit tester. The kind that has the alligator clip for the ground, and the LED pin that you touch to the wire...I bought this because pivot sends you a little crappy tester with the unit that is just an led with a long wire attached to it. Wow once I figure this out I will make sure to do a write up on this little kit of horrors. Thanks for your help vancouverbc
Ok I did successfully hook the pivot headlight controller up...No thanks to the instructions. If you have purchased the pivot headlight controller throw the directions in the garbage, and use my walkthrough I posted.
Modified by nismo180sxS-13 at 12:18 PM 11/14/2006
Modified by nismo180sxS-13 at 12:21 PM 11/14/2006
