Pivot Bushing
A forum for the Nissan Quest... minivan lovers unite!
leesan
Car: 2004 Quest SL
Hello, I'm new in here.I have 04 Quest SL. Recently, I took my Q for an alignment. I was told that I have a damaged pivot bushing. What happens when I step on the brake pedal is that the pedal pulsates. Just like when you have warped rotors. But, rotors are fairly new and turned, relatively new pads (oem) and new tires in front were installed. And, I was told that it is NOT a ball joint. Then, what is it?
basskronick
Car: 1st gen Q
Pivot Bushings? Wow, i haven't anyone use that term since the 40's and 50's domestics..... I would guess they're talking about the control arm bushings, kinda sounds like it from the symptoms.
Return to “Quest Forum”
