pistons w/stock bore
black93fastback
Car: 1993 s13 fastback
does anybody know if arias pistons fit to our stock connecting rods? if not i'm looking for low compression pistons w/stock bore for a turbo setup..
PandaS14
Car: S14
you run a pretty good risk of not having good compression when rebuilding an engine with stock bore. Much better idea to get slightly oversized pistons and get the block bored and honed to guarantee a good seal.
sil80drifter
Car: 1990 240SX Hatch
People do get just new rings and hone the block to them, you know. Why get new pistons when you don't have to?
sil80
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
re-ring with std pistons and new rings is ok, but will not last nearly as long or perform as well compared to a fresh bore. Its worth the few extra bucks to get it bored and new pistons. Also with forged pistons in std bore after a full hone you will be on the wide end of the piston tolerance, fighting piston fit, noise, and ring seal. Your in there already so do it right.
sil80drifter
you are ruining my day! lolI don't wanna buy new pistons and get the block bored, that's extra $$ I don't have.
sil80
